It is currently Wed Jul 23, 2025 11:56 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 03, 2008 5:10 pm
Mike Mahar wrote:
Colin S wrote:
Waddy, it will have a close relative of the chunky marmalade, I haven't been given it yet, but it is a horrendously expensive real amber oil varnish, apparently it takes three old hags with a big cauldron on some Scottish moor to make it from eye of newt and tongue of frog or some such, anyway it's one of those things that if you need to ask the price....
Al Carruth has often said that if you want to start brawl enter a room full of violin makers and whisper the word "varnish". He also tells a story where a writer was visiting a bunch of violin makers interviewing them on their craft. Each of the makers extolled the virtues of their particular custom varnish formula. He would ask them what it was and, often, they would share it provided that he kept it a secret. The ironic part was that they all had basically the same formula. There was one exception. One very prominent builder said that he got his at the hardware store. I don't recall the builder or the brand/type of varnish.
I'm not implying that you shouldn't invest in this varnish. A lot of violin builders who know far more than I do swear that this is a critical component and that you shouldn't skimp.
Mike, I agree that a cheaper analine-dye spirit varnish would probably be just as effective in colouring and protecting the wood, but would it give me the same satisfaction or pride in my workmanship as using as close as possible the old traditional varnish? These old genuine ground Baltic amber varnishes date back hundreds of years and have been tried and tested over the centuries. Titebond would have held the wood together very well, but I still used HHG.
I use quite a range of old recipe varnishes and finishes (The one kept in a chunky marmalade jar for instance that was used on my recent Torres copy) in my restoration work on the historic instruments I do for the museums. When I build a historic replica instrument, this one is taken directly from measurements of the Liotti Stradivarius, probably the most original survivor which I have been priviledged to hold and my wife to play, I like to use as original finish as possible. OK there as nothing special about Stradivari's varnish it was just the available varnish at the time, and probably adds little to the sound, but why not get as close as possible for the sake of a few pounds (well quite a few pounds in fact!).
PostPosted: Thu Apr 03, 2008 6:09 pm
I always wondered why violin builders gets so riled up about their finish when guitar builders really don't seem to get anywhere near as vocal and crazy... You'd think the type of finish you use would have a similar impact on the violin as it would on a guitar, but I RARELY see guitar builders have such lengthy discussions and debates on it as violin builders... Why is this? Does the type of finish really affect a violin's sound that much more than a guitar? Or is it all just tradition and a bit of myth?
PostPosted: Thu Apr 03, 2008 7:40 pm
Well done Colin (er not done but getting there) but I'd expect nothing less from the only lute maker I know!! The very first acoustic instrument I made was a violin. Just wish I could play the thing. It still hangs in my shop so I picked it up today after seeing your post and noticed it has a small crack in the top. I guess it has dried some so I will now get some repair experience one of these days. I look forward to finished pictures and some of your wifes music.
PostPosted: Thu Apr 03, 2008 9:05 pm
Surely if one of your objectives is to do a reproduction you have to do the varnish as well. Now all you have to do is take your vitamins, hit the Gym and hope that modern medicine cures old age so that you can live to find out if it sounds good in 200 years.
PostPosted: Fri Apr 04, 2008 1:27 am
Looks good to me, Colin!
I'm going to have to build a fiddle soon too. My daughter will soon outgrow her 3/4 size which means she will confiscate my nice old German violin and I'll have to build one for me.
About the varnish beehive ; you are not cooking it yourself, correct? How can you sleep??? :o Kidding! So where are you getting it, or is that a secret?
I assume all the wood is from the Alp region somewhere?
PostPosted: Fri Apr 04, 2008 5:38 am
Correct! The top is in fact Fiemme.
PostPosted: Fri Apr 04, 2008 7:46 am
Are you putting a baroque or modern neck on it?
